Stock gearing?
Check out this data. Also, you can check the final drive ratio from the info below:
TRANSMISSION: NSG 370-MANUAL, SIX-SPEED OVERDRIVE
Availability: Std.-All models
Description: Synchronized in all forward gears and reverse,
multi-rail shift system with top-mounted shift lever
Clutch: Hydraulic actuation
Gear Ratios:
1st: 4.46
2nd: 2.61
3rd: 1.72
4th: 1.25
5th: 1.00
6th: 0.84
Reverse: 4.06
Axle Ratio: 3.21 Std., 4.10 Opt. (Std. on Rubicon)
Overall Top Gear: 2.69 Std., 3.44 Opt. (Std. on Rubicon)
TRANSMISSION: 42RLE-AUTOMATIC, FOUR-SPEED OVERDRIVE WITH VARIABLE LINE PRESSURE
Availability: Optional
Description: Electronic governor, electronically controlled converter clutch
Gear Ratios:
1st: 2.84
2nd: 1.57
3rd: 1.0
4th: 0.69
Reverse: 2.21
Axle Ratio: 4.10
Overall Top Gear: 2.83
TRANSFER CASE: NV241 COMMAND-TRAC
Type: Part-time
Operating Modes: 2WD High; 4WD High; Neutral; 4WD Low
Low Range Ratio: 2.72:1
Center Differential Type: None
TRANSFER CASE: NV241OR ROCK-TRAC
Type: Part-time, heavy-duty
Low Range Ratio: 4.0:1
Gear Ratios:
1st: 4.46
2nd: 2.61
3rd: 1.72
4th: 1.25
5th: 1.00
6th: 0.84
Reverse: 4.06
Gear Ratios:
1st: 2.84
2nd: 1.57
3rd: 1.0
4th: 0.69
Reverse: 2.21
Axle Ratio: 4.10
Type: Part-time
I think I remember it having the 4.10s....cause it was just like the Rubicon with out the front axle on it.....It does have the sway bar disco also....I love it either way.....
iv'e got the '09 x with s package and still has the lousy 3.21 gears . so that's why i kept with 33's and not going 35 . i learned all this because of this great site . although when my 2.5 lift get's installed and my 33"s wear out i might just switch up anyway . you can never shift to much , can u ? lol ..
Maybe we've got different expectations? I keep seeing people wanting more power (Hemi, anyone?) and here I'm pleased with the power of mine.
Jamie
mine did...................come with 3.21:1
and 3.21's aren't big enough a ratio to turn "big" tires well. They're good for 29"-31", but most people with 32"+ swap out to 3.73 or 4.10, or go crazy with 4.88, etc.
Gas mileage is a big concern, too. Is it a daily driver or a rock crawler?
Location: Simi Valley, Ca., Taylorsville, Ut. and places in between
1 Post
I got the build sheet for mine from the Jeep site.
Heres the linkClick on the send us an email and the window will open for the info
http://www-5.chrysler.com/webselfservice/chrysler/index.jsp?screenName=customer&country=us&emailUrl= goToEmailForm%28%27R%27%29
Hope this helps.
Hope this helps.
I found a cool way to get a build sheet without waiting. I went to a dealers website and viewed a new jeep they were selling. There was a link to view the window sticker, so i clicked on that and replaced the VIN in the address bar with my own. And just like that, there is my window sticker....
Hope this helps, here is the link i used---
http://www.chrysler.com/hostc/window...yslerJeepDodge
Just replace the VIN with yours....
How did you enter a different VIN?
