Stock Headlight question
+1^
Forgot about that. It will also work. My 02 Ram had the same feature. Turn your ignition off, then your light switch. It will start a headlight timer. Just don't forget to turn off the headlight switch before you get out of the jeep.
If you do not have the steering wheel mounted buttons & the "menu" button, I recall seeing a section on how to change the light settings in the manual. You might need to have the keyless entry as well though. It is with the settings for beepng the horn when locking, flashing the lights, etc.
Thanks for the reply..
I do not have a keyfab or the steering wheel buttons.
Yeah I used to do it all the time and just all the sudden it stopped with no change (mods) to the Jeep.
If it's an '08, I'm guessing you still have the original battery? Maybe it's an indication of your battery getting ready to go or something else causing low voltage? Just a guess, nothing to really base it on but it might be worth looking at.
