Stock rims and tires
My new Unlimited Sahara should be in shortly and I really hated the factory tires. How wide are the stock 18" rims and how big a tire will they hold without a lift?
the wheel should be 7.5'' wide.
the largest that usually fit without additions (spacers or lifts) is 275/70/18 about a 33/12/18
And Welcome to the forum.
anymore questions just ask.
You will find a far better selection of tires in the 17" size...I just put a set of 17x8 rock crawler rims on the 08 Sahara and shod it with a SMALLER snow tire...245/75R17, at 30.75" tall instead of the 31.8 of the stock tire (losing about 3% in height)...
I wanted to use the Blizzaks for a variety of reasons and that seemed to me to the best compromise. Plus I was able to use P series snow tires and not LT series at about 1/2 the cost.
In this case, I think that Jeep screwed up in the 18" stock wheel diameter on the Sahara.
Howard
Howard
Howard
I have 3,000 miles on the Bridgestone Dueler A/T Revo 2.
http://www.tirerack.com/tires/tires....omCompare1=yes
They are extremely quiet.
With the softtop up or down, you cannot hear them even at 80.
Excellant control in the rain or dry.
I just did 300 miles this past weekend in a romp to Philly from NH at the tail end of the big blizzard. I had read these tires were much better in the snow than the bridgestone duelers our Jeeps were shod with. They certainally are. They are not as as good a lugged off road tire, but there is no whining and no blocks to wear unevenly after 20,000 miles. If you punch it in a turn on snow, they have a controled break at which point the ESP kicks in. If you drive normally/sanely, they are super.
I went up to a 265-70-18. that gives you .9" more diameter (eg a 33") along with 3/4" more width. Helps to fill the wheel wells. Barely noticable with the 6 speed).
A bit more money, but they have a wear rating 20% higher than the stock duelers so they should be a better deal long term. They are the most quiet AT tire I have even bought (have bought lots over the past 20+ years and 4 suvs).
All in all, I am very smitten with the new rubber for my driving (mostly highway, a lot of snow & hills, towing, and as a Jeep tractor to move trailerloads of mulch, soil etc around the yard).
By the way, did I tell you how quiet they are?? :<)
homer
Hey Colt you seem like a pretty knowlegdable guy, my question is if i run a 275/70/18 on stock sahara wheels with a tf leveling kit do i need spacers as well?
