Stock Rubicon Rock Rails
Old Mar 29, 2007 | 06:49 PM
broom's Avatar
Default Stock Rubicon Rock Rails
Has anyone put the stock rubicon rock rails to use yet? Hit a rock, tree, etc.? I read that someone was able to use a high lift jack on the rock rails. I wonder how well they work when they are doing the job they are made for; when the weight of the jeep crashes down on a rock. I also wondered about after-market rockers that attach to the frame. Would you have to remove the stock rails to make room for aftermarket ones that connect to the frame, or would they fit under (in addition to) the stock rails?
Old Mar 30, 2007 | 07:04 AM
broom's Avatar
Thanks, I assume your sheet metal remained intact. Right? Sounds like you have been putting your JK to good use.
