Stock Suspension Question
Old Dec 16, 2011 | 05:28 AM
EClass's Avatar
Default Stock Suspension Question
If the Rubi's shocks and springs taller / better than the X or the Sahara's?
Old Dec 16, 2011 | 05:35 AM
CodyB4C's Avatar
Shocks are better, springs it all depends on the part numbers. I believe 19/60 is the tallest/stiffest combo, but you will only see a difference if you out them on a 2dr.
Old Dec 16, 2011 | 06:42 AM
Jtrain496's Avatar
They aren't really taller, maybe half a coil, but most are stiffer. You won't get an actual lift but higher numbers will result in less sag and effectively lifting your ride height.
