Stupid question?
This is prob a dumb question but the handle that jacks the seat up and down broke and i was wondering is tbere any way to fix it? Or any way to move the seat up or down if broken... Looks like those plastic teeth are all but one snapped off
How do I remove the handle and does handle have to be removed to move it down cause I've put a torx bit in and it won't turn in either direction... But handle is still on but i just want the seat down...
When mine broke years ago, I just yanked the handle off since it was stripped anyways. If you can access the torx bolt, then it shouldn't matter if the handle is on to turn so the seat lowers. There might be a small cotter pin holding the handle on? Maybe the torx is jammed or something is wedged in your seat preventing you from lowering? I can take a look at my handle later.
