Stupid soft-top question
Just put my top and windows back on for the first time in months. Is it best practice to zip the back window in first? or the sides? my sail flaps don't seem to be sitting right
I start the zipper a few inches, then velcro the top corner by the door covering where i just zipped so that the door channel part holds when i put it in and the velcro is started for when i am to that step. The i put the flap in the door panel/surround then zip it to the top corner by the rear, put the bottom in the body channel, then finish zipping shut and Velcro
As I always struggle with zipping in the rear window I did it first this time.
It went on perfectly ( zipper lined up great!) the second try. Did this make a difference... who knows.
Most likely the biggest difference was cleaning and lubricating the zippers first, but I will be zipping in the back first for now on.
My rear zipper is a little quirky but I never have a problem putting either of them on in any particular order. There's usually enough give to pull the rag either way. Proper lube is a must. Also put some type of zipper pull on. It'll make it a heck of a lot easier.
