Suprised at diff gunk on magnetic plug 4500 miles
Changed my front and rear diff fluids today so I could get the higher viscosity synthetic fluid for towing. My jeep is only a few months old with 4500 miles. The rear fluid looked dirty compared to the front. Both magnetic plugs had "stuff" on it. I suppose microscopic bits of metal from break in. The rear had more than the front. I'm talking about 1/8" build up of stuff on the rear plug.
I'm not worried. I assumed some break in wear was normal, hence the reason for the magnet. Rear fluid was just s little darker in color and less see through. Glad I changed it.
Originally Posted by Sargeant
Don't beat me up here, cause I'm new to this field of science, but I would venture to say the reason for the darker color in the rear diff would be to the greater work load it has had compared with the front. I'm assuming that the majority of the 4,500 miles were driven in 2H and not 4H.
When you have new gear sets installed it's important, but not commonly done, to break in the front gears as well as the rear. I had a truck regeared and I pulled the rear driveshaft and drove it around in 4hi for an hour. Comprehensive? No. Probably better than most though. Got a couple heat cycles into it like recommended.
Theoretically since that front is always spinning now it's sort of breaking in as you drive around but as he said far more load is going on the rear axle. The factory recommended break in procedure works for everything in the drivetrain, not just the engine, but since the front axle isn't always under load it won't see the same wear.
I had so much gunk after my re-gear that when comined with the heat of the gears breaking in, it gummed up both locker plungers in the diffs. Had to get them replaced at my 500-mile fluid change.
-Adam
-Adam
