swap coils
Hello all, i have a question about my stock suspension and that is can i that off just my 07 wrangler x coils and shocks and swap out with a Rubicon coils and shocks so i can get extra lift for bigger tiers so i don't have to buy a lift kit. If i can do it is just a coil and shock change or do i have to change more then that and would it be easier just to buy a lift kit. Will it make a big difference in hight from stock x and a Rubicon. Also what is everyones take on the coil spring spacers do they work well or should i buy a coil system and what is the best to buy if i have to so i can get a about a 2.5" lift.
Thank You for everyones help on this.
Thanks N2rock on the info about the height that there is none i thought there was. you said that you are using a coil spacers, do you think that there is a ride and all around handing /performance on using coil spacers instead of all new coil lift kit. when it comes to the budget i can go ether way but if i can save a little I'll save and use it on another mod.
Thank all
Thank all
