Sway bar plug
Old Oct 11, 2008 | 12:14 PM
RubyRed44's Avatar
Default Sway bar plug
Im trying to reset my sway bar to make my sway bar light stop blinking. I am going to disconnect the battery and connector that goes into the sway bar since Ive read a few threads that say that is the best way to try and fix the sway bar light issue.
My question is... How do i unplug the connector that goes into the sway bar unit. I dont want to break anything as i do this.
Old Oct 12, 2008 | 04:23 AM
jkkat's Avatar
There is a little lever that you pull or push. (forget which way it goes)
Old Oct 12, 2008 | 05:50 AM
mtnmedic's Avatar
if you have the silly plastic "guard" still on, it is a pain in the butt to get to, but if you have it off already, you should just be able to undo the lock and pull the connector out.
Old Oct 14, 2008 | 05:59 PM
RubyRed44's Avatar
Got it off and disconnected the battery also. It cleared the MIL light and sway blinking so now im good to go. Went and tested the sway bar and it is working fine now.
Anyone who has a blinking sway bar light should try disconnecting the battery for 10 mins before taking it into the stealership.
Old Oct 15, 2008 | 08:21 AM
Good advice I will keep it in mind
Old Oct 15, 2008 | 08:26 AM
marcoseddi's Avatar
Default warranty
soundslikea warranty issuethat you shouldnt even mess with let the dealer take care of it
Old Oct 16, 2008 | 03:31 PM
RubyRed44's Avatar
The dealer said it would be $1200 to fix cuz they are lazy and didnt even pull the codes. I took 10 mins to clear the codes and everything is working fine. If disconnecting the battery doesnt fix it then id take it to the dealer.
