synthetic oil, v.s. traditional oil
2013 jeep rubicon. 3.6 manual. I live in Anchorage Alaska. Also how do you get the "change your oil" light off?
I am changing my oil i want to know if i can go synthetic. i have changed my oil once so far and im due again.
Ok i know some people are just biast... but why... Thanks for the tips Jeff
Reset it every time you change even if it hasn't come on again yet.
You can change to synthetic anytime. If so, you can extend the change interval a good 25% further than the OCI says. (if it goes off at 4000 mile, you can go to 5000, no worries) Just don't exceed the warranty requirements.
You'll probably want synthetic for the cold weather. When does that start, next month? :-)
It's all in your manual, if you didn't get one you can download one from jeep.com. I think they'll mail you a paper copy if you ask for one.
Oil is a religion. If you want better info, check out BITOG forum.
2013 jeep rubicon. 3.6 manual. I live in Anchorage Alaska. Also how do you get the "change your oil" light off? I am changing my oil i want to know if i can go synthetic. i have changed my oil once so far and im due again. Ok i know some people are just biast... but why... Thanks for the tips Jeff
Sent from my Obama phone using JK-Forum
I have used Dino oil all my life and routinely keep my cars past the 150,000 mile mark. I have never had engine problems. I have had two separate friends run synthetic that allowed them to run longer oil changes and replaced motors under 50,000 miles. NOTHING is better than routine maintenance.
To reset the OCI, turn key to ON, pump gas pedal to floor three times within ten seconds. Then turn to off.
