taigate rattle...need help...
hey there fellow jeepsters...
i took off my spare wheel mount to install quadratec brake lights...
and 'something' fell into the tailgate on the inside and is now loose...
how the hell do i get it out...i can't get it from the inside face of the gate...
i've prized off the plastic covers and all i see is more sheet metal...
do you think if i remove the mount again and then take off that 'air-plate'...
i'll be able to see whatever it is...it's metal and rattling around loud...
what the hell is it anyway...a cable-guide or something...
Yea, I have had it apart when installing a lock actuator. Most likely a plastic plug. It you snake a coat hangar in there and drag it you might beable to get it to where you can get it or use a telescopic magnet just to make sure it isn't a sert weld or screw.
thanks for the info...it sounds like a metal part...
i'll take off the 'flapper -plate' this w-end and fish around...
cheers...
in answer to the mail below...all the nuts are there...
i had thought of a dropped one being the problem...
but all the carrier bolts tighten so all the nuts must be intact ... !
cheers...
