Tailgate Fail!
#22
I've had cooper 35" tire on the back for a year now. I'm not really regular wear and tear loosened the tailgate. You guy's have to have some kind fo defect or smacked it when wheeling.
#26
I don't know if I missed reading this or what, but I didn't see anywhere if it was your hinges or the bolts holding the tailgate to the hinges? Do you know which is loose?
#27
So far I have been checking mine frequently. I looked at the weight of a stock 32" tire: 48 lbs. The weight of my 35" tire is only 16-18 pounds heavier than the stock tire (running a stock rim). I don't think that amount of weight distributed evenly around the wheel would make that much of a difference. I could see if you are running steelies or a much heavier wheel/tire combo.
#28
I've got a PJ rear, it's decent, had some repair issues with it.
I really like the look of the Red Rock Fab carrier. If I was doing it all over I'd get that, the River Raider drop-down carrier and crusher corners, or the EVO rear system that they're just starting to release.
#29
#30
Was your spare resting on the rubber bumpstops on the tailgate or did you use a spacer? I am trying to prolong having to buy a carrier. My spare is tight against the bumpstops and I don't have any vibration...
