Thin Wall Sockets
Old Feb 28, 2023 | 08:59 AM
Russ's Avatar
Veteran: Navy
Default Thin Wall Sockets
Anyone know where I can purchase a 1/4 inch drive 7mm thin wall socket. I am trying to remove the Recirculating Door Actuator and my craftsman standard 7mm socket will not fit due to interference of the plastic.. Need a thin wall socket.
Thanks!
Old Feb 28, 2023 | 10:27 AM
Russ's Avatar
Veteran: Navy
Default Different Socket Size
Turns out that the other screw was not a 7mm socket size, it required a 9/32" socket. Bad assumption on my part thinking they required the same size socket.
Old Feb 28, 2023 | 10:28 AM
Russ's Avatar
Veteran: Navy
Old Feb 28, 2023 | 10:30 AM
Jay2013jk's Avatar
Veteran: National Guard
Community Favorite
I would presume you searched Google. I searched the major tool companies .. NO LUCK.. You might be reducing the outside to make your own thin wall.. IF so use a cheapie
Old Mar 1, 2023 | 06:50 AM
peachferrari's Avatar
Glad you figured it out. I was going to suggest a nut driver as sometimes they have a slimmer profile than a socket.
Old Mar 2, 2023 | 03:55 AM
Russ's Avatar
Veteran: Navy
Did not need to buy a thin wall socket.. Turns out the other screw was a 9/32 when is was supposed to be another 7mm.
Old Mar 5, 2023 | 05:15 PM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
In cases where I need a thin wall socket I just grab a cheapo and put it on the grinder. Bingo thin wall. My 1310 driveshafts use one.
