Third brake light post - what is it made of?
Old Mar 26, 2013 | 08:40 PM
melor's Avatar
Default Third brake light post - what is it made of?
Does anyone know what the post for the third brake light is made out of? Tapping on and feeling it, I cannot tell if it is plastic or metal. I am thinking of using it to mount a horizontal piece of square tube and then use the square tube to hold up rear work/backup lights. Before I start buying the parts and drilling holes I want to know what I am working with, but as crazy as it seems, I cannot tell what the post is made out of. My original thought was plastic, but I am thinking it is some light metal.
Any thoughts are appreciated.
Paul
Old Mar 26, 2013 | 08:44 PM
Tycho's Avatar
The curved bit is some sort of metal as I've worn slightly through the paint with by rear recovery strap bracket.
Old Mar 26, 2013 | 08:58 PM
Woody's Avatar
Vet Army
Default Metal
Sure cuts easy with a plasma cutter, don't even ask how I know, great sparklees!!
Old Mar 26, 2013 | 09:21 PM
TURTLECON's Avatar
Plastic in the front, metal mullet party in the back.
Old Mar 27, 2013 | 05:40 AM
MikeRM's Avatar
It looks to me that the tire carrier and brake light post is all one piece cast Aluminum.
Old Mar 27, 2013 | 05:48 AM
Four Low's Avatar
The tire carrier and extension for the CHMSL are a metal alloy , like die-cast aluminium The light and its plastic stalk comes off with the removal of 4 Torx screws. The alloy is easy to cut , a hacksaw or thin metal cutting disc will do the job. Don't forget to move the wiring harness out of harms way.
Old Mar 27, 2013 | 06:49 AM
JKJA10's Avatar
It's cast aluminum. Found that out when I cut mine down so that the light sits low and inside the wheel.
