threaded shift knob
I want to buy a custom shift knob (www.wiseguycustoms.com) but the JK isnt threaded, if I wanted to tap and dye it so it IS threaded, what would be the closest thread size? 10mmx1.5?
Last edited by HappyCurmudgeon; Oct 13, 2008 at 04:29 AM. Reason: Removed hyperlink.
Tell you what SSGT Hughes...I'll work on it tomorrow, let ya know what I find out.....
BTW, I got out of the AF as a SSGT in 2001..served for 10 years.
I solute you for your service brother..
To remove the shifter, you pry on the part of the boot that is farthest from the dash, there is 2 clips, then tilt it ahead and the first part will lift off.
Then there is another insulator under that, it's a little harder to do but you have to unclip it the same way as the first one.
Once that is lifted up, it's either a T-40 or T-45 bolt on the shifter.
Then just pull up and the shifter will lift off the transmission with the 2 boots still attached.
someone else has asked the same question... try a search
