Throw out bearing squeal
Old Apr 16, 2016 | 01:16 PM
pmmahoney2214's Avatar
Default Throw out bearing squeal
I just replaced the clutch throw out bearing pressure plate had the flywheel checked and resurfaced and everything was good for one day then suddenly this squeal started and will not stop you get it on the road in gear sometimes but it's constant at an idle in neutral with the pedal all the way released push the pedal in just slightly until you feel pressure and it stops and sounds perfectly fine any suggestions where to start or possibly graphite on the tob or grease?
