Thud when going to reverse?
Originally Posted by TomOH
Hellhound before you go nots check your driveshaft make sure it is sitting in tightly on the yoke ends also check for play in the shaft you know get under the jeep and see if you can rock it or move it, most times that's what the thunk is, but if it seems ok then the next thing is have the tranny looked at. Oh is it standard or auto? Can Make a difference let me know if this helped.
Were the joint cap sits in the yoke if it has clips or snap rings make sure they are all there I have seen them come out then the shaft will move but look fine & no I'm not knocking the mechanic you would be surprised how often they are forgotten about. The other thing is if it has straps check the bolt that hold the strap to the u-joint cap to the yoke. This might be a dumb question but dose the u-joint have a greases fitting? The other thing is grab the driveshaft were it hooks up on the rear and move it in the direction of all for caps at that point you should have no play.
This can be normal because your suspension and drivetrian is going from no load or a forward load if the nose is pointing down an incline to a reverse load.
my wifes WJ does the exact same thing. it gets more noticable as time goes on because they is more ware and slack in the drivetrian.
What I was talking about was holding above the slip and below to see if there was any play I have helped my brother-Inlaw for quite a while and he makes driveshaft in his business.
Well it gets better. I got under there to check the driveshaft with the engine running and now I hear a knocking sound. I though it was the engine but Im not sure, upon further inspection it sounds like where the engine meets the tranny, could the torque converter be knocking like that and would that be the cause for the thud as well?
Mines been making some funny noises lately. Been getting more noticable. When I spin it, it makes this noise. Was surprised how easy the transfer case was moving when I shook driveshaft. Sorry about crappy video. Went to edit it, but can only save as a stupid adobe file.
http://www.youtube.com/watch?v=TXHUMvhNqgc
