Ticking Noise ... Help me identify!
Old Mar 26, 2016 | 08:40 PM
feroxjb's Avatar
And yes.. it is after it gets warmed up.. I don't actually hear it initially. It isn't until I've let it idle for a long while or if I've driven it for a bit.
Old Mar 27, 2016 | 05:18 AM
silverfox82's Avatar
Originally Posted by feroxjb
Silverfox, did you ever figure out what the sound was or are you still ticking away?
Nope still searching. Thinking about pulling valve covers to search for collapsed springs or broken rocker arms. Not happy about it but seems like the next step
Old Apr 1, 2016 | 08:56 AM
smhuey1's Avatar
Im in the Same Boat 2008 Sahara starts ticking after about a mile or 2. and increases with RPM's
Drives me nuts, Keep us updated on the whats and hows. Forgot to Mention im @ 84K
Old Apr 1, 2016 | 10:58 AM
crazybones340's Avatar
This could be a number of things from valves to oil viscosity to which octane of gas you use. My old xj use to tick like that when I used lower octane fuel and when I would put premium in it would stop. I also used thicker oil one time like 10w40 and it sounded even worst. Finally I said screw it and just dealt with it. It really didn't hurt anything other than be annoying.just my $0.02.
Old Apr 1, 2016 | 11:02 AM
SoK66's Avatar
Mine turned out to be a badly cracked driver side exhaust manifold.
Old Apr 1, 2016 | 11:18 AM
Does it start making the ticking after it gets to around operating temperature? My motor sounds perfect until it gets to around operating temperature, and then it ticks away
Old Apr 1, 2016 | 02:22 PM
catahoula's Avatar
I have heard about the cracked manifold. Mine has been ticking forever. Yours sound more of a knock. I believe mine might be the lifters and heard it is common...98,000.
Old Apr 1, 2016 | 11:46 PM
feroxjb's Avatar
I've recently replaced the driver side exhaust manifold. I'm going to check it tomorrow. If all looks good and I don't find any leaks, I've already purchased a timing chain kit to try and see if that's the cause.
Using a mechanics stethoscope (Harbor Freight), it still really isn't any easier to trackdown. It doesn't seem like it's in the top but I guess we will see.
Old Nov 25, 2016 | 06:04 AM
jassch's Avatar
Did it turn out to be the timing chain?
