Tie rod ends bad?
Old Sep 3, 2010 | 06:29 AM
Hellbound13's Avatar
Default Tie rod ends bad?
I'm running a heavy duty tie rod and drag link, have had them both on the jeep for about a year and a half now, 20,000 miles.
When I rock the steering back and forth my mechanic can see a little movement to them but he said it look like they are rotating or pivoting slightly (all four ends). It's very slight.
Us this normal or are these ends bad? They have been greased regularly every 2k.
Thanks!
Old Aug 19, 2011 | 12:56 PM
TmBtc12's Avatar
Thanks!
Interesting that you posted. I had my jk in for an alignment earlier today and the shop said I need a new tie rod before they can align it.
Old Aug 19, 2011 | 04:45 PM
Flip94ta's Avatar
I had my Nissan maxima in for three alignments before I realized I needed new tie rods. Maybe the shop is helping you out. You can check your tie rods by jacking up one tire and placing your hands at the 3 and 9 o'clock. Try to steer the tire, if there's a metallic click or clank when shifting from one direction to the other that's a bad tie rod. It can be as little as 1/16-1/8 of free play to throw if off.
You can also check wheel/hub bearings next by placing your hands at 12 and 6 oclock and trying to rock that way. I don't think JK's have many issues there but many independent suspension vehicles do. I've found three bad bearings this way.
