Tie Rod Ends - Hex Hole on Threaded Shaft
I am replacing the OEM Tie Rods.
I noticed that there is a 7mm hex hole in the threaded Shaft.
Anyone know what this is for?
Yep. You will need to hold the shaft in place with a hex wrench to get the end tightened enough to stop the shaft from turning. Then you can use a torque wrench to finish tightening to spec. Otherwise the shaft will just turn and it won't tighten all the way.
