Tipm help
Old Sep 16, 2021 | 07:27 PM
eric71's Avatar
Default Tipm help
I had to replace my tipm in my 2008 Wrangler because it put my Jeep in safe mode. I put the new one and after about a week my headlights won’t turn on. Any help would be greatly appreciated. I did a soft and hard reset. Thanks
Old Sep 18, 2021 | 07:47 PM
tazzboo's Avatar
Not sure if this will help or not. I found on my 2012 that I couldn't get the light to go out after a new set of Wheels Tires and Sensors. Even the tire shop couldn't figure it out. Well on a maybe moment. I tried airing the tires all the way up to 45 psi. After about less then 5 mins the light went out and every thing was perfect. I then Aired the tires back down and the system was still happy. Can't hurt to try.
Old Sep 19, 2021 | 05:55 AM
user 729872082's Avatar
Former Member
I think the power module was replaced. I don't know why the headlights wouldn't turn on assuming they worked at first. If everything worked at first is it possible there is a loose ground or wire?
Old Sep 19, 2021 | 07:42 AM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Did you get a dealer or shop with WiTech software to do the work? If not to both parts of the question I would say to get hold of someone with WiTech and diagnose. WiTech is the Jeep factory software.
