Tire killer?
Old Sep 25, 2007 | 03:14 AM
  #21
moun10eer's Avatar
Thanks Rubimon, Jake_Blues and mkjeep for clarifying! I might go to the trail tomorrow or the the day after and good to know that I don't have to worry about it.
Agree with you Rubimon and mkjeep, and I don't like the way it looks either. I'm going to trim the corner sometime soon.
Old Sep 25, 2007 | 09:36 AM
  #22
easttnruby's Avatar
That pice isnt an issue on my rubicon. The factory rock rails cover it and make it a blunt shape. Have considered cutting it though to make the wheel well more uniform. Havent had any issues with 35's, even under serious flex but it would provide some peace of mind.
Old Sep 25, 2007 | 10:41 AM
  #23
medbender's Avatar
35s 4 '' lift and no problems. if its not broke, im not fixing it
Old Sep 25, 2007 | 10:45 AM
  #24
hiontach's Avatar
instead of cutting or bending that piece, you could always just take your tires off all together! then you wouldn't EVER have to worry about the tire being pierced.
Old Sep 28, 2007 | 02:17 AM
  #25
moun10eer's Avatar
Okay, yesterday morning, before I headed to Hawkins Mountain Trail, I cut the rear corners and Rubicon rocker guard. Some of you clarified that the corner doesn't hit the 35" tires, but I didn't like the way the corner and the stock rocker guard stick out.
AFTER:
As you can see with this photo, if the corner wasn't cut, it would be very very close to the tire, I think. It was really nice that I didn't have to keep checking to see if the corner/rocker guard damage the tire or visa versa.
just re-attatched the plastic cover on the rocker guard. (The stain at the corner is from the dirt and rain from the today's trip... not from cutting).
BEFORE:
Old Sep 28, 2007 | 07:46 AM
  #26
RotorHead's Avatar
Default My Version
Caution!! Tell your wife or girlfriend about this after it's done. I did not use the proper method of attack and got sucked in. "You are not going to cut up your brand new Jeep?" I just told her it was the latest craze, everybody's doing it.
After a couple of weeks, she said aren't you glad you didn't cut it. Then I showed her and told her I cut it two weeks ago. Once it was done, she actually liked it.
Here's what I did.
I removed the rock rails and cut 2-1/2" from the end. use a straight cut so the end cap will fit like the original. Drill a whole in the bottow for the end cap retaining plug, then shoot the exposed edges with a rattle can. Once the paint dries, insert the endcap and the rail is done.
Mark a line with a sharpy on the rocker body where you want to cut. Try to make it blend with the amount you removed from rock rail. Cut it with a sawsall. Paint the edges with touchup paint from the dealer. I used marine epoxy to fill the gap in the middle. It takes a few days for the epoxy to dry, so you may want to go back and paint over it when it's done, which I still need to do.
Old Sep 28, 2007 | 09:00 AM
  #27
Rubidonn's Avatar
Originally Posted by Jake_Blues
I'd try flexing your Jeep out first before you go hacking parts off. Remember, as your axle comes up, it also moves backwards somewhat, because of the arc the control arms move in.
-E
x2... I'm running 35's w/the stock Rubi Rockrails and body seem still there... it's close, but won't touch because of the arc mentioned above... when you flex out, it ain't gonna get closer... it'll move back slightly.
As was also mentioned, if you go w/37's, I'm confident you'd have to cut.
Old Sep 28, 2007 | 11:21 AM
  #28
CLACKEY(_!_)'s Avatar
35" Nittos on top of a 3" Full Traction Ultimate. I have never touched the pinch weld and I have stuffed it way up there.
[IMG][/IMG]
