Tire question
Old Jul 18, 2012 | 08:03 AM
drivingfool's Avatar
Default Tire question
I ran over a nail and plugged it. The tire (35x12.50x17 gy mtr) loses goes from 30psi to 25 psi in about 3 days.
Does it make sense to have the plug pulled and go for a plugpatch, or what?
Old Jul 18, 2012 | 09:09 AM
Originally Posted by Rebelliousw0n
did you dip/spray the tire to check its the plug leaking? did you cement the plug or just pop it in? If you have access to a tire machine plug/patch is the best way to go but plug/glue is acceptable.
No cement, just a plug.
Old Jul 22, 2012 | 03:23 PM
Gman*2007's Avatar
Thats why I buy my tires from Discount Tire. Lifetime flat repair, balance & rotation.
Old Jul 22, 2012 | 03:56 PM
TheBeale44's Avatar
Discount tire does flat repairs for free no matter where you bought it. However I'm not sure if they can fix it if a plug is in it already. Pretty sure its against regulations
Old Jul 22, 2012 | 04:39 PM
Butch's Avatar
My buddy works a one can't fix it if it's plugged
Old Jul 23, 2012 | 02:57 AM
airforce26yrs's Avatar
I am pretty sure this is your problem. Always use cement along with the plug. You can probably push the plug into the tire and replug with new plug with cement. But first make sure it is the plug leaking my dipping it in a tank or running water over it to see if it bubbles.
Old Jul 23, 2012 | 05:07 AM
SCMatt's Avatar
unfortunately worked in a tire shop for years and saw that all the time. If you did not use cement that's most likely your problem. You can push the plug through, and redo it, but I would just take it to a local tire shop and have them do an interior patch and remount/balance. Probably cost $20 but worth it.
