Tire rotation ?
Old Oct 24, 2012 | 08:18 PM
bfschor's Avatar
20%? Wow! So does most everyone do this with their spare?
Old Oct 24, 2012 | 08:24 PM
KeepJeep10's Avatar
I don't rotate the spare I am buying a used tire for my spare and just using it when I have a flat. The spare just needs to get me somewhere to get my tire fixed. It's pointless to buy 5 tires when you have to replace. You don't see hondas rotating there little donuts lol. Just my 2 cents
Old Oct 24, 2012 | 08:27 PM
woodyvw9's Avatar
Veteran: Coast Guard
That what I do every other oil change. Then when you get bigger tires, because you will get bigger tires, you start fresh with a new set of five an don't have to worry about having an undersized spare.
Old Oct 24, 2012 | 11:03 PM
TheTerminator's Avatar
When replacing tires, I've only ever had to buy 4, not 5. Buying 4 oversized, all terrain tires is bad enough. I'd prefer not to have to buy 5!
Lol. You will be buying them less often, if you rotate 5 tires. If you had, say, 10 tires, then you won't have to buy new set of 10 tires for a very long time.
Old Oct 24, 2012 | 11:08 PM
Because Hondas don't come with a full size spare tire. If you don't rotate the 5th tire, then it goes to waste. And when your current set wears out and you decide to try a different tire, then... you now have a different spare tire. Not only the tread pattern will be different, but the overall diameter will likely also be different, even if they both suppose to be 35" tires or whatever. God forbid you decide to move up/down a tire size.
Old Oct 25, 2012 | 02:52 AM
lanslide's Avatar
I you don't rotate the spare - it will dry rot over time and will be unsafe to use (especially if you leave it uncovered). I found this out on my last Jeep 93YJ that I kept for 19 years. This time - I'll rotate my 12JK's spare and extend the life of my 5 tire set.
Old Oct 25, 2012 | 03:21 AM
lulu2533's Avatar
Yep, I always rotate my spare.
Old Oct 25, 2012 | 03:28 AM
Whiskey Bravo's Avatar
There is absolutely no reason other than sloth to NOT rotate the spare. It doesn't cost you more since you extend the life of your set, your tire doesn't go bad over time, you can get to the tire repair shop at a leisurely pace, and you don't have to buy a wasted tire when you decide to change brands or size on the next buy.
Old Oct 25, 2012 | 03:36 AM
Rule18's Avatar
Doing a five tire rotation is the only smart move for all the reasons the previous posters noted (taking for granted that you've got five of the same tire).
To one of the previous posters that said "you don't see Hondas rotating their donuts", REALLY?
Old Oct 25, 2012 | 03:45 AM
echoshotz's Avatar
is it ever too late to rotate in a spare? I've done one rotation but the shop didnt rotate them the way I'd like (I know I should've done them myself..) so would it be bad to throw the spare in rotation now?
