Tire size calculator
Hey anybody know where there is a tire size calculator. I trying to figure out some number sizes and compare them
Thanks
Dave
Thanks
Dave
I like this one.
www.rimsntires.com/specs.jsp]Custom rims, wheel tire packages for your ride - RIMSnTIRES.com[/url]
Here's another
www.1010tires.com/Tools/Tire-Size-Calculator]Tire Size Calculator - Tire & Wheel Plus Sizing[/url]
Don't go off of what the sidewall says. If you go to the manufacturers website they will list the true dimensions. You can take 10 35x12.50R17's and they will all have different true dimensions.
Tire size chart
The chard shows the width of the tire in the Width column. To find the height simply refer to the column for the tire aspect ratio and add the rim size. For example a 315 size tire is 12.402 wide and if it is going on a 17" rim and it is and aspect ratio of 70 the overall tire height would be 17.362(from chart) + 17 (rim size) = 34.362"(overall tire height)
I made this chart as a ready reference as it is so easy to use.
Hope this helps
KG6SLC aka Eugene
Hope this helps
KG6SLC aka Eugene
