Tire Size Options on Stock Rubicon X
Sorry for the newb question...
Just ordered a JKURX this week and wanted to confirm that I can install 285/70R17 Duratracs on 17" AEV Pintler Wheels with out lift or leveling kit.
I have seen mixed reports on this.
I may be considering a Teraflex leveling kit to remove factory rake.
Any info on leveling kits would also be helpful... Coil type vs. spacer type.
The Jeep will be a DD for at least a couple years until we get another vehicle. Then the real Mods will begin!
Thanks
Thanks
you will be fine. If you were going to keep stock rims you would have a little rubbing on sway bar at full turn and the rear driver side control arm would be close. But the pintlers have another inch of back space. I ran 285/70-17 Open Country at2's on stock rims with on lift on my 14 jkur and only rubbed at max turn. Off road flexed you will rub the fender flairs however. I kept the 285/70-17's for 2000 miles and moved up in tire size to 285/75-17. I would suggest going bigger right off the bat. it is amazing how soon 285/70-17 look small. I went with a 2" aev lift and it works perfect for my size tire.
yes stock rims and Spidertrax spacers. Been very happy with the set up and I too did not want the tires to stick out past the flairs. I had that on my last one and these are right at the edge so don't get the crap up on the door handles so bad
did you run the bigger 285 75 17 without any lift ?
..thanks
