Top not fitting tight
Old Sep 25, 2012 | 04:01 AM
ram2938's Avatar
Default Top not fitting tight
Need some suggestions 2007 soft top does not seal tight at the windshield. I can pull down on the top and it takes all the wind noise out but won't stay tight any suggestions would be helpfully it does tend to get very loud and not at all uncommon to get wet when it's raining
Old Sep 25, 2012 | 12:39 PM
crodgers618's Avatar
I have a 07 also and mine just started doing that on the passenger side I think I'm just going to get a new one next spring.
Old Sep 25, 2012 | 12:48 PM
Vin's Avatar
Vin
You need to swap out the plastic header for the newer metal one.
Old Sep 25, 2012 | 12:50 PM
jpone's Avatar
Header piece is bad. 2007 it was plastic, and it was later changed to metal. You can buy the replacement piece and it will fit great again, unless you have extended warranty, in which case I believe it is covered.
Old Sep 25, 2012 | 12:52 PM
Scallywag's Avatar
I've wondered the same thing on mine! So if you're not under warrenty, which I imagine alot of us 07 owners aren't, how much are the metal ones?
Old Oct 5, 2012 | 08:44 PM
jpone's Avatar
About 200.00 installed. Cheaper than a new top and works great.
