torn drive shaft boot
Many people are driving around with torn boots. Yes, it will need to be replaced over time (DS), but I'd worry about that when the time comes. As far as I know, you can't replace the boot on the factory DS.... You will be surprised on how long it will last with a torn boot. Just give it some frequent checks to make sure it's not leaking. The factory DS can't be rebuilt or greased from what I've been told.
Considering the U-joint is often replaced as a preventative maintainance measure when you pull the tranny to change the clutch, looks like a clutch change just got a whole lot more expensive.
The big boot covering where the two halved of the driveshaft slide in/out? Or the little boots in the joints at either end? If it's the big boot, just keep the splines greased as best you can, and continue driving on it. If it is the joints at the tcase/pinion, you will need to replace the shaft. If they will not cover it under warranty, consider moving to an aftermarket double cardan instead of a factory shaft. (depending on lift height, you may need a set of adj ca's though).
Just saw that you have 4 inches of lift on a 2door. You need to swap it for an aftermarket, and will want rear upper arms to set the pinion angle.
"Short sighted" my butt!! Why should they sell you a $20 boot, when they can hit you for a $750+ shaft? Driveline isn't the only shaft going on here! Shame on Jeep!
As nthinuf said in another thread, with a 3 14" lift, the front shaft boot polishes the xfer case until it tears, when under flex. I will try his advice to keep it greased & make it last until the $ fairy poops in my yard! Makes mud holes nerve wracking, though!
If MKJeep doesn't see your post and reply, shoot him a PM. He has some pics floating around here somewhere of his driveshaft after removing the metal band and replacing with a zip tie. Don't know how long he ran it like that, but doesn't hurt to ask.
Originally Posted by nthinuf
Zip Tie.
