Torquing suspension components..
Old May 27, 2009 | 03:57 PM
Hellbound13's Avatar
Default Torquing suspension components..
When you guys torque suspension components do you always have someone to help you. Doing it alone I can't figure out how to torque some components where you need to hold a wrench on the other side. Is there any other way short of a helper?
Old May 27, 2009 | 04:09 PM
mkjeep's Avatar
I just ussually let the end wrench hit against something metal, then knock it off with a hammer, scoot back if you do this though.
Old May 27, 2009 | 04:13 PM
I can find places the wedge a wrench against the axle or trackbar brackets but what do you do for the control arms? Also I can't get a torque wrench up on top of the drag link where it meets the pitman arm..
Oh and on the rear trackbar do you take the wheels off to do it?
Old May 27, 2009 | 04:27 PM
mkjeep's Avatar
No on the rear trackbar. And for others I use a cheater pipe on the end of the wrench to but against something. Drag link/ Pitman? Can't imagine it would be anymore than 60-75ft lbs. Stuff like that I just get as tight as I can with a reg wrench without getting crazy on it.That's just the way I do it though. Maybe some pro's on here can give you better info.
Old May 27, 2009 | 04:29 PM
4x4jkx's Avatar
All i know is the front trackbar is 125 ft lbs and is a PITA to get to with a 1/2 inch drive torque wrench.
Old May 27, 2009 | 04:52 PM
bly109's Avatar
x2 I have a fairly long wrench to do this, but a pipe over the end helps too.
Old May 27, 2009 | 05:32 PM
09rubicon's Avatar
I use a fairly long wrench along with my torque wrench. It also helps to have good forearm strength, so I try to work mine out a few nights a week!!
Old May 27, 2009 | 06:10 PM
Where can I get one of these pipe wrenchs that fit over the box end of the other wrench?
Old May 27, 2009 | 06:15 PM
paramaniac's Avatar
i use a set of vice grips on the opposite side. snug it up and hit it with a hammer to take it off
Old May 27, 2009 | 06:16 PM
But wouldn't the vice grips just spin with that nut?
