Torx bit?
Old Jul 25, 2007 | 07:49 AM
GMAN's Avatar
Default Torx bit?
Is this the right size bit for removing the hardtop and doors?
It did not come with the dual top package. You think it would have.
Old Jul 25, 2007 | 07:54 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Doors are a T-50.
Soft Top bow assembly is a T-30
i dont have the hardtop to verify, but the manual says: T-40
Old Jul 25, 2007 | 07:55 AM
pup's Avatar
pup
It will remove the hard top and windshield hinge bolts, but not the doors. Doors require a T50 bit. I'd just try to borrow one from somewhere since you can leave the nuts off when you put the doors back on without any problems.
I agree, Jeep should have provided tools to do the job...
Old Jul 25, 2007 | 08:05 AM
rock342's Avatar
Default Throw those bolts away
Then after you have taken them off with your T40, throw them in the trash and replace with these:
Hardtop Quick Disconnect T-Bolts
from Cooltech LLC. You'll still need to keep your T40 for the windshield, but you won't need it for the hardtop ever again.
Old Jul 25, 2007 | 08:07 AM
GMAN's Avatar
Thanks all. Very, very helpful.
Old Jul 25, 2007 | 08:29 AM
JKcarp's Avatar
Just buy a full set. You'll need the other sizes somewhere else on your Jeep.
Old Jul 25, 2007 | 10:55 AM
I'd buy a small set that comes with it's own little rubber boot, and keep that in the little storage cubby in the back of the jeep, that's what I did so it doesn't get mixed up with all my other tools. Plus you never know when or where you might want to take the top off.
Old Jul 25, 2007 | 03:27 PM
00pumpkin's Avatar
Go to Sears and buy a full set, or if your rich - Snap-on
Old Jul 25, 2007 | 06:08 PM
HEFTY's Avatar
Does anyone know off hand what size the threads are on these bolts?
I guess I could go pull one, but I was curious if any one here knew.
HEFTY
Old Jul 25, 2007 | 06:15 PM
neil17's Avatar
the only reason I bought these Torx bits are cause of my JK. I invested $12 bucks for a 6 piece torx set in which I only needed 2 of the sizes. I wish they would of provided the torx bits cause now I have 4 torx hand tools (T60, T55, T47, T45) that I'll probably never need to use.
