Tow package?
Should not take you more then 20 mins.
I got the wiring kit from Quadratec for $16.99 M#92015-17.
And yes it just plugs right in behind the left taillight.
The only real thing you need to think about is where
you will connect the ground wire. I put mine under the
mounting screw of the taillight, it worked.
My 09 X unlimted has tow package 3:73 trac loc
I'm not sure I'm crazy about the 3:73's
Most guys around here, that do alot of wheel'in want lower gears but since I mostly drive mine on the street, I wonder if I'd be more pleased with 3:21's getting better gas milage keeping the revs down.
I also think about less shifting if I had 3:21's.
1st gear is so short. with my 3:73.
I skip gears all the time to make it to 6th going down the road .
I'm doing 45mph in 6th gear driving local or doing 80 on the freeway 6th.
People say it tow better with the gears or better power if you add bigger tires wit 3:73 but I think I'd just downshift if I needed to and again feel like I should have got 3:21's
I just sent the wire through the frame. The frame as small holes at different point along it. By small I mean a inch or two around. After hooking up the wire behind the taillight, you will find a hole to the outside at the bottom. Run your wire through that hole and then from the underside I found a small hole in the frame to run the wire to the center area. Just used these holes to somewhat hide the wires. Hope this helps.
Where is the connector? My wire is shaped like a "T" and the only "end" I see is the connector for the panel with the flip cover. Where do the wires originally go? If I can find this, I can take it and thread it through my frame.
On the threading through the frame part. I only did mine part way through the frame because of the "flat four wire" plug mine has. If you want to thread it the full length of the frame in the center. You might have to cut the wiring to fit through some of the smaller holes. And resplice them back after pulling it through. Good luck.
I went with the Mopar harness and indeed the install was a snap and the "christmas tree" snaps (for lack of a better word) made the install a snap and as clean as could be since the snaps line up perfectly with the frame and made for an idiot proof clean install.
Trailer Tow Group: Hitch receiver, 4-Pin Wiring Connector, 3.73 axle ratio.
Includes:
Trailer Hitch Receiver
Trailer Sway Damping
Trailer Tow with 4-Pin Connector Wiring
Includes:
Anyone persuaded their dealership to flash the Trailer Sway Damping (aka Trailer Sway Control) program to their ECU?
yeahh i did mine to all by myself and it took me no more then 25 min its a joke to install, 4 bolts make sure your jeep it cool its easer to do and the wiring harness just plugs in its reallyyy simple to do.
