JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   Towing with a JK??? (https://www.jk-forum.com/forums/stock-jk-tech-12/towing-jk-160739/)
Fitba101 Jan 24, 2011 08:01 AM
Towing with a JK???
I have the base model 08 JK unlimited. I want to start towing a small pop up camper, but not really sure all I need. I just installed a rugged ridge tow hitch, but have no electric going to it for the camper brake lights. Do I just need the towing wiring harness?? If that's the case where do I hook the harness up to??
mbfrosch Jan 24, 2011 08:04 AM
You can buy a kit that simply plugs into the tail lights, no cutting or splicing wires.
shindiggsxr Jan 24, 2011 08:10 AM
I got mine at the dealer, You just pull your driver side light and plug it in and run the wires down.
jcs07jk Jan 24, 2011 08:37 AM
Same with mine, got my harness from eBay for about 15.00 and install took a few minutes. Really easy
Enclocal Jan 24, 2011 08:39 AM
you can also find the factory tow kit at various online suppliers :thumbsup:
sum-daze Jan 24, 2011 09:02 AM
Try this, this is what I used. :thumbsup:
h t t p://www.quadratec.com/products/92015_8001.htm
TJeeper Jan 24, 2011 09:29 AM
Does your camper have brakes? My small popup weighs in at about 2200lbs fully loaded. Living in Colorado I wouldn't ever consider towing more than 1000lbs without trailer brakes, but that would be up to you. A 7 wire plug is more complicated than the 4 wire one, but still doable. There are some write ups on the boards, but basically I tapped into the left brake harness for lights and ran 2 wires to the front for power and brake activation.
Road Warrior Jan 24, 2011 02:43 PM
I pull a 5 x 10 covered trailer on prob. loaded with construction tools at long distance never had a problem/have harness
RobtTxRubi Jan 24, 2011 05:15 PM
x2 on trailer brakes.:clap:
im-ocd Jan 24, 2011 06:11 PM
I'm in the same situation.
I put a receiver hitch on my Wrangler Unlimited for infrequently towing a small utility trailer.
© 2026 MH Sub I, LLC dba Internet Brands
