Towing with a JK???
Old Jan 24, 2011 | 08:01 AM
Fitba101's Avatar
Default Towing with a JK???
I have the base model 08 JK unlimited. I want to start towing a small pop up camper, but not really sure all I need. I just installed a rugged ridge tow hitch, but have no electric going to it for the camper brake lights. Do I just need the towing wiring harness?? If that's the case where do I hook the harness up to??
Old Jan 24, 2011 | 08:04 AM
mbfrosch's Avatar
You can buy a kit that simply plugs into the tail lights, no cutting or splicing wires.
Old Jan 24, 2011 | 08:10 AM
shindiggsxr's Avatar
I got mine at the dealer, You just pull your driver side light and plug it in and run the wires down.
Old Jan 24, 2011 | 08:37 AM
jcs07jk's Avatar
Same with mine, got my harness from eBay for about 15.00 and install took a few minutes. Really easy
Old Jan 24, 2011 | 08:39 AM
Enclocal's Avatar
you can also find the factory tow kit at various online suppliers
Old Jan 24, 2011 | 09:02 AM
sum-daze's Avatar
Try this, this is what I used.
h t t p://www.quadratec.com/products/92015_8001.htm
Old Jan 24, 2011 | 09:29 AM
Does your camper have brakes? My small popup weighs in at about 2200lbs fully loaded. Living in Colorado I wouldn't ever consider towing more than 1000lbs without trailer brakes, but that would be up to you. A 7 wire plug is more complicated than the 4 wire one, but still doable. There are some write ups on the boards, but basically I tapped into the left brake harness for lights and ran 2 wires to the front for power and brake activation.
Old Jan 24, 2011 | 02:43 PM
Road Warrior's Avatar
I pull a 5 x 10 covered trailer on prob. loaded with construction tools at long distance never had a problem/have harness
Old Jan 24, 2011 | 05:15 PM
RobtTxRubi's Avatar
x2 on trailer brakes.
Old Jan 24, 2011 | 06:11 PM
im-ocd's Avatar
I'm in the same situation.
I put a receiver hitch on my Wrangler Unlimited for infrequently towing a small utility trailer.
