TPMS Question
Looking to switch out my tires for take off BFG mud terrains. Question, should I use the sensors in my current tires or use the ones that come in the take offs. I've heard that I may run into issues if I don't use my original sensors. Is this true?
Thanks
Thanks
I would recommend sticking with the original sensors if at all possible. New sensors are not cheap and not all model years use the same frequency.
I am pretty sure you cannot mix the two frequency TPMS on a jeep. You could change all the wheels from the older frequency to the newer frequency but I believe that requires programming by the STAR Scan (at the dealer, or maybe a good tire shop?)
If you need one new sensor that matches the frequency of the other ones, then you can mount it and the jeep should eventually recognize it. At least that was supposedly true of the older (grey valve stem) models.
As for ease of replacement: The older ones are held on with a nut, the newer ones just get pulled through like old-school rubber valve stems. In any case you have to dismount/mount the tire and balance the wheel.
I BELIEVE all the above to be true. BUT I talked to a lot of people and got a lot of conflicting information.
My 2008 has the (stupid) aluminum nuts that all cracked due to corrosion. One failed entirely and the sensor fell into the tire. I have replaced all the valve stems and nuts but I am still using the original sensors. Next year, when I buy new tires (maybe new rims, too!) I will upgrade to new sensors with the rubber stems.
If you have the older style valve stems, inspect the nuts for cracks. Also remember the battery in the sensor only lasts 7-9 years.
I got valve stems (Schrader 20020 TPMS Service Pack, $5 each) and service kits (valve core, nut, grommet, and cap)(Schrader 20013 TPMS Service Pack, $6 each) on Amazon. So about $60 for 5 tires.
Then it is just a matter of the cost of dismount/mount and balancing.
