Trans Temp and fluid level
I wanted to check my trans fluid level and I guess I'm confused with this diagram.
https://drive.google.com/uc?id=178nE...CB8ow1Ks8oJYkH Where are these temp readings coming from? I guess I originally assumed that these temps vs trans dipstick levels where that they were the trans fluid temps. So I connected my BlueDriver OBD2 scanner to see if I could get some trans temperatures to check my trans fluid level. However, I'm not seeing a way to get a reading for the trans temp. Are these engine temps? Here's what BlueDriver is reporting for the JK 3.8L Live Monitor Supported PIDs when connected to the OBD2 port. I'm not seeing a trans temp supported PID. https://drive.google.com/uc?id=1zZk9...IQxo0jz2uEDwIO How do you get trans temp readings? |
Strange. My BullyDog pulls transmission temp on my 3.6L '13. I'd think that the BlueDriver would....should be a common setting, and surely your '09 has a transmission temp sensor.
Maybe infrared temp gun getting a reading from the trans pan? I just did my transmission service (posted an update to that thread for some tips) and I definitely think I'm a little over full. It's really hard to get a good reading but I have also found that cleaning the dipstick with brake clean allows for a slightly better reading. I think after the service I had about 4 liters in the catch pan and when I put 4 liters back in it didn't even register on the stick. I put 5 in and now I think I could be a little over full. The extra trans cooler could be the difference on this but I am not sure.
Rednroll,
The temp readings in the picture you posted above are transmission fluid temps. My AeroForce gauge gets the temp readings from the OBD2 port. The OEM trans temp sensor is in the transmission sump. The temp readings and their corresponding levels on the 42RLE dip stick are taken from data in the factory service manual. |
Originally Posted by ronjenx
(Post 4343205)
Rednroll,
The temp readings in the picture you posted above are transmission fluid temps. My AeroForce gauge gets the temp readings from the OBD2 port. The OEM trans temp sensor is in the transmission sump. The temp readings and their corresponding levels on the 42RLE dip stick are taken from data in the factory service manual. Below is the list of "ALL" PIDs the BlueDriver supports....it's a very long list and I did not notice anything which seemed related to Trans Temp. Maybe I'll dig Torque Pro back out since you can manually add PIDs in that app from what I recall. https://drive.google.com/open?id=1wy...fl55m8T_YtwwTU Anyone happen to know the PID for trans temp? |
With TorquePro, you actually have to go into the settings and select to activate/download the Chrysler/Dodge/Jeep automatic transmission temperature PID*. I just walked a friend through it day before yesterday.
*Settings / Manage extra PIDs/Sensors / (menu--the three dots at upper right) / Add predefined set / Chrysler/Dodge/Jeep/Mercedes / (select desired PID based on vehicle model) |
