Transfer Case
Old Dec 24, 2012 | 10:09 PM
The Riz's Avatar
Default Transfer Case
What weight lube should be used in stock 2012 JK transfer case ?
Old Dec 24, 2012 | 10:11 PM
carolinajk's Avatar
[QUOTE=The Riz;3350880]What weight lube should be used in stock 2012 JK transfer case ? atfplus 4 i think,but ck the owners manual
Kolton10's Avatar
There's a good write up on project jk and I think it tells you
Old Dec 24, 2012 | 10:12 PM
Kolton10's Avatar
ATF+4 I believe
Old Dec 24, 2012 | 10:13 PM
Shecky's Avatar
Hope this helps buddy
Old Dec 25, 2012 | 06:10 AM
ronjenx's Avatar
This is from the 2012 Owner's Manual, and the JK Owner's Manuals for the other years say the same thing:
"Transfer Case MOPAR ATF+4 Automatic Transmission Fluid or equivalent licensed
ATF+4 product."
The use of a licensed ATF+4 product is important for the transmission.
I suspect the t-case is a lot more tolerant of other types. I'd stick with ATF+4 while under warranty.
Here is a list of approved ATF+4 sources.
[TABLE="class: MsoNormalTable"]
[TR]
[TD="colspan: 3"]Please note Licensed ATF+4[SUP]®[/SUP] Brands have been updated as of April 1, 2012.[/TD]
[/TR]
[TR]
[TD] Advance Auto Parts ATF+4[SUP]®
[/SUP]Amalie ATF+4[SUP]®[/SUP]
Auto Extra ATF+4[SUP]®
[/SUP]AutoZone ATF+4[SUP]®
[/SUP]Carquest ATF+4[SUP]®
[/SUP]Castrol ATF+4[SUP]®
[/SUP]Castrol Transmax ATF+4[SUP]®
[/SUP]Chevron ATF+4[SUP]®
[/SUP]Citgo Transgard ATF+4[SUP]®
[/SUP]Coastal ATF+4[SUP]®[/SUP]
Craft+4 ATF+4[SUP]®[/SUP]
Federated Auto Parts ATF+4[SUP]®[/SUP]
[/TD]
[TD="width: 34%"] Great Wall ATF+4[SUP]®[/SUP]
Havoline ATF+4[SUP]®[/SUP]
MAG 1 ATF+4[SUP]®[/SUP]
Mobil ATF+4[SUP]®
[/SUP]Mobil Super ATF+4[SUP]®
[/SUP]Mopar ATF+4[SUP]®
[/SUP]NAPA ATF+4[SUP]®
[/SUP]Northland ATF+4[SUP]®
[/SUP]O’Reilly ATF+4[SUP]®
[/SUP]Parts Master ATF+4[SUP]®
[/SUP]Parts Plus ATF+4[SUP]®
[/SUP]Pennzoil ATF+4[SUP]®[/SUP]
[/TD]
[TD="width: 33%"] Petro-Canada ATF+4[SUP]®[/SUP]
Prime Guard ATF+4[SUP]®[/SUP]
Proline ATF+4[SUP]®[/SUP]
Pronto ATF+4[SUP]®[/SUP]
Pure Guard ATF+4[SUP]®[/SUP]
Quaker State ATF+4[SUP]®[/SUP]
Ravenol ATF+4[SUP]®
[/SUP]Sinopec ATF+4[SUP]®[/SUP]
Super Tech ATF+4[SUP]®
[/SUP]Tutela Transmission Force4 ATF+4[SUP]®[/SUP]
Valvoline ATF+4[SUP]®[/SUP]
[/TD]
[/TR]
[/TABLE]
Old Dec 25, 2012 | 03:03 PM
moe jk's Avatar
Make sure you use synthetic..
Old Dec 25, 2012 | 03:05 PM
moe jk's Avatar
And yes atf + 4
Old Dec 25, 2012 | 03:08 PM
Zombie Hunter's Avatar
ATF+4 is synthetic.
