Transfer case cable
Old Mar 5, 2014 | 08:07 PM
Enduroking's Avatar
Default Transfer case cable
Have an 07 unlimited and the last month or so the transfer case cable came off the t/c twice... I figured it was missing something because it went back on so loose... I went to local jeep dealership (with very little help), and purchased a plastic bushing and it went on. It worked great for about 2 weeks and came off again... Is there something else that I'm missing?? I'm about ready to tie it up with bailing wire!!! Thanks for any help!
Old Mar 5, 2014 | 08:33 PM
Battlefrog21's Avatar
It was Chryslers way of saving money and is pretty common. Check out this thread and do away with the plastic bushing...
https://www.jk-forum.com/forums/jk-w...repair-177095/
Old Mar 6, 2014 | 04:15 PM
MudCHUD's Avatar
the bushing is gone. $3 . pop the bushing in the cable first and pop it on the nipple. buy 2. they sometimes disappear for no reason. easy field fix too. MUD UP!
Old Mar 6, 2014 | 04:24 PM
stagedtrip's Avatar
I used a 1/4" E ring in place of a bushing, been over a year and no issues and I wheel often
Old Mar 6, 2014 | 04:42 PM
MudCHUD's Avatar
yup. but eventually the e-ring will cut the shift prong off :(
Old Mar 6, 2014 | 04:43 PM
stagedtrip's Avatar
Why is that?
Old Mar 6, 2014 | 06:22 PM
karls's Avatar
If the cable is causing enough of a headache then consider going to the Novak cable. It will not fail you.
Old Mar 9, 2014 | 07:26 AM
MudCHUD's Avatar
Why is that?
the e-ring is hardened spring steel and the shift linkage is not. vibration during normal driving and off roading use will start to cut a grove in the shaft...thereby making a nice snap/score in it. I may be an alarmist but....I've seen lesser things cause mayhem. I work on jeeps for a living.
Old Mar 9, 2014 | 07:45 AM
BuckLisa's Avatar
I spent the $ and installed the Adavanced Adapters Transfer case cable and shift upgrade. It's pricey and a little pain, but it will never fail now. http://m.youtube.com/watch?v=5OrMzFQ2ssg&autoplay=1
Old Mar 9, 2014 | 07:50 AM
ronjenx's Avatar
Anything is possible.
The e-rings I have seen in use were always on softer steel. Never had a problem as long as the e-ring was of the proper size.
