Transfer case linkage
Old Apr 13, 2011 | 10:26 AM
Dtking's Avatar
Default Transfer case linkage
I've lost contact with my transfer case, the shifter moves freely... Anyone else had this problem?! I noticed at the transfer case the linkage was still connected but missing a cotter pin so I replaced that! I also looked to where it should run into the cab and all I see is a boot elbow with nothing running through! Will this be a hard replacement? Do autozones/oreileys carry these parts??
Old Apr 13, 2011 | 10:33 AM
Sharkey's Avatar
Not sure where yours broke, but if you have to replace a substantial portion of it you may want to look into the Advance Adapters cable and mounting system. It isn't cheap ($189) but at least it permanently cures the problems with the plastic connectors.
Old Apr 13, 2011 | 10:34 AM
zeppo's Avatar
It's super common. The plastic retainer clip breaks either at the t-case or the shifter. I'll see if I can find one of the threads.
Edit: searching and posting a link is annoying on my phone, search the thread title "4 wheel drive cable break" good info and some pics of fixes.
Old Apr 13, 2011 | 10:47 AM
Dtking's Avatar
Thanks! I'm pretty sure that it broke at the shifter because it came loose at the tc first and when I replaced the pin I noticed it wasn't connected at the shifter anymore! :-(
Old Apr 13, 2011 | 04:56 PM
Mad-Hatter's Avatar
It can come disconnected at both places. Broken cable more likely, but possible to pop both off. I picked up spare bushings at the dealer for like $0.30. I find most are broken or pop off from yanking on the shifter too hard. It shouldn't take more than 1 finger to shift it when the gears are sync'd right
