Transmission Fluid Leak
Old Jan 8, 2024 | 06:37 AM
Rzaraza14's Avatar
Angry Transmission Fluid Leak
Morning all! I'm at a lose here. I have 2010 JKU that went into limp mode. Pulled all the codes and did the proper fixes. Changed trans solenoid valve, input and output speed sensors, pan gasket, etc. Still have a leak thats completely baffling me. ATF fluid appears to running down from somewhere on the passenger side and dripping from my steering stabilizer. Whole passenger side is soaked with a good coat, shocks, sway bar, steering stabilizer, etc. It's infuriating because I've tried everything to locate this leak and have no luck. Any help would be greatly appreciated.
Old Jan 10, 2024 | 07:28 AM
resharp001's Avatar
Loved
Community Favorite
Tranny fluid on a steering stabilizer seems like something coming from directly above. Your 2010 does not have a tranny cooler I don't think, and what is directly above is the PS fluid reservoir. That seems too obvious, but it's worth asking if you've inspected the power steering system that also uses ATF4??
