Uneven tire wear
Old Apr 13, 2017 | 01:34 PM
Illdill's Avatar
Default Uneven tire wear
Hello, I am getting excessive wear on the outside of the front passenger tire. If I understand correctly this is due to the camber being off which can be adjusted at the lower control arm. But how do I measure it so that I can know what I have done after making an adjustment?
Thanks!
Old Apr 13, 2017 | 01:42 PM
ronjenx's Avatar
Thanks!
Have you had an alignment check? If not, get one before you consider making any corrections.
Camber is not adjustable on the JK.
Most times, when JK camber is off, the top of the tire leans in. This is the opposite from what would cause the outside of the tread to wear.
Too much and not enough toe can cause one edge to wear, too.
Old Apr 13, 2017 | 01:55 PM
Illdill's Avatar
So which would cause the outside of the tire to wear, too much toe in, or out? I would guess toe in since that would put the outside edge forward.
Old Apr 13, 2017 | 02:02 PM
ronjenx's Avatar
Could be.
Old Apr 13, 2017 | 04:03 PM
Illdill's Avatar
No, not since I bought it. There aren't any jeep dealerships in my area and since I am new to the area, I've yet to discover any shops I would trust.
Old Apr 13, 2017 | 04:22 PM
ronjenx's Avatar
Try a tire shop. Some will check alignment for free and give you a read-out.
