Unlimited turn radius
Are you sure about that? I'm not saying I don't believe it, but I can't see why it would be true. In either case (wide or narrow front track width) my wheels turn the same number of degrees to the side don't they? I would think turn radius would be a function of wheel base and angle of the wheels mostly. For example, would a trike have a significantly better turn radius than a car with the same wheel base?
I guess the actual radius is the same, but now since the wheel is actually out farther, wouldn't it track wider, hence making turning in a narrow spot more difficult? For example, if you just barely cleared the curb without spacers, you would hit the curb with the spacers, so the bottom line is you need more room to turn.
The first thing my wife did when test driving the unlimited was to check the turning radius. She fell in love with the JKU, when she found out it was tighter than her 99XJ.
