URGENT- North GA limping home with death wobble.
Need help asap. Bent bracket on axle with steering damper and (tie rod, whatever the bar is that has a big bend to clear front dif)
Steering damper is bent and leaked out fluid. Have death wobble around 50 but need to make it to Atlanta tonight. Anyone with a spare damper or a jk to compare bracket with? I-24 Now, about 15m away from I-75 south.
Please call asap
Patrick
770-856-6286
Please call asap
Patrick
770-856-6286
Something else has to be wrong. You can drive a JK without a steering Stab. Just take the steering stabilizer off and it should drive fine. If it doesn't you might want to check your trackbar and Draglink. Wish I was closer I could have helped you get back on the road.
http://blog.bushwacker.com/wp-content/uploads/2013/01/jeep-wrangler-tj-front-end-diagram.jpeg
Thanks for the suggestions. I replaced bolts with 9/16, brand new tie rod and new control arms, torqued to spec. New stock steering damper, and measured toe in.
All take off parts still look good. No unusual appearance. Holes are still round, no ovalling or wallowing out. Getting tires balanced now.
Had friend turn wheel while I inspected and felt around, nothing seemed out of place.
How do I check ball joints? What else should I look for?
No DW since replacing damper, but I know the damper is not the cause or solution for DW...
Easiest way to check for BAD ball joints is to lift Front tires off ground, grab a crow bar, stick under tire, and pry up and down. If there is more than the allowable play (i think .25") then they're probably bad.
Mine were SHOT! Had about 1" of up and down play in the tire,lol. New Ball Joints and haven't had an issue in over a year.
