using oil?
Sounds like quite a bit to me, but you'd be shocked how much oil you can burn before a motor is "out of spec" according to manufacturers.
I'd dump another quart in and keep running. Check the oil now and then and see if it gets better or worse as your mileage gets higher.
You may just have to get in the habit of adding a quart halfway between your oil changes.
