Washer hose to back window
Old Apr 29, 2008 | 09:19 AM
snowbdr88's Avatar
Default Washer hose to back window
Has anyone else had issue with this coming off when they try to use the rear washer? Mine will come off & shoot in the rear of the truck.
A bit annoying, to say the least!
Old Apr 29, 2008 | 09:23 AM
jeep's Avatar
There is a little plastic clamp that should be on there. if it is not all the way on the spout on the hard top it will keep blowing off when you try to use it. The clamp also holds the plug to plug the line when you are not using the hardtop.
Old Apr 29, 2008 | 10:37 AM
Mark Doiron's Avatar
Originally Posted by snowbdr88
... Mine will come off & shoot in the rear of the truck.
What truck? Is there a truck tailgating you?
Old Apr 29, 2008 | 10:43 AM
yetibear's Avatar
Well at least no kittens were harmed in the making of this thread.
Old Apr 29, 2008 | 10:48 AM
SASQUATCH's Avatar
mine came off first time I used it and sprayed our 11 yr old daughter right in the face....pretty funny
it doesn't do it anymore..
Old Apr 29, 2008 | 11:29 AM
SASQUATCH's Avatar
Originally Posted by N2rock
seems to be one of those things you need to periodically check (or buy a really tiny hose clamp).
Mine was fine for months. Then one day I had my twins sitting int he back seat, and I went to use the spray. Next thing I have two 11 year olds screaming "Hey! What the...!!! Where's all this water coming from?!"
that's awesome. I ought to hook it up out the rear window for goofy "gotta follow too-close" drivers
Old Apr 30, 2008 | 06:53 AM
snowbdr88's Avatar
At least I didn't call it a car
Old Apr 30, 2008 | 06:58 AM
jkkat's Avatar
If you do not get that clamp holding the plug on right, that tube will shoot off all the time. BUT it does not work that well with the soft top on and neather does the rear wiper or defroster.
Old Apr 30, 2008 | 07:09 AM
Joker92's Avatar
Old Apr 30, 2008 | 08:30 AM
Rubidon's Avatar
I don't have a problem with it coming off, but I do have a problem with it getting pinched to the point no fluid will squirt. Looks to be to long. Maybe I'll cut it shorter so I only have to worry about it coming off
