View Poll Results: Has your water pump failed?
Yes its has!
97
15.06%
No it has not.
530
82.30%
Whats a water pump?
17
2.64%
Voters: 644. You may not vote on this poll
Water pump poll.
Old 09-20-2012, 07:13 AM
  #171
jeepintileguy's Avatar
34000 miles and I was getting a squeaking sound from my water pump. Dealer replaced it under warranty.
Old 09-20-2012, 07:33 AM
  #172
yo_marc's Avatar
Just replaced my water pump at 121K miles.
It was lightly weeping for a good 30K miles. Not the water pump itself, just the gasket. I put a few RTV patches on during that time, but figured I should finally get around to doing it right.
The gasket was toast. The water pump and engine block mating surfaces has surface corrosion. Had to lightly coat the new gasket with RTV to make sure it sealed ok. (The water jacket itself was pristine.)
Glad I changed out the pump too -- it had a slight 'click' in the bearings if you rotated it by hand.
Old 09-20-2012, 08:33 AM
  #173
Jeep(NV)'s Avatar
17,000 and mine went, bad bearing!
Old 09-20-2012, 08:53 AM
  #174
Tricky0s's Avatar
20,000 miles and no issues so far
Old 09-20-2012, 04:58 PM
  #175
adammj's Avatar
Just hit 90k - original water pump. Woot! (knock on wood)
Old 09-20-2012, 05:04 PM
  #176
brandonbooth's Avatar
Mine bit the dust at about 60k
Old 09-20-2012, 05:17 PM
  #177
k0260's Avatar
just about 50K, OE water pump still - hopefully indefinately
Old 10-18-2012, 02:51 PM
  #178
marmot74's Avatar
20k. Water Pump being replaced. 2012.
Old 10-18-2012, 05:27 PM
  #179
Malan35's Avatar
Mine is 07 with 55k. Water pump went began leaking a few months ago. Pump was still good but since I had it off to replace the gasket I replaced the pump anyways.
Old 10-18-2012, 08:26 PM
  #180
boxcar's Avatar
08 was toasted on a long trip, about 42k mileage
Quick Reply: Water pump poll.
