weird cruise control issue
Old May 28, 2010 | 03:08 PM
liquidg's Avatar
Default weird cruise control issue
cruise control will turn on when I am stopped or rolling very slow. Once I start moving with it on (over 5mph) it turns off and will not let me turn it back on.
Was wondering if this has something to do with having 35's. Will a programmer like the flash paq fix this?
I searched around but couldn't find the same problem.
Old May 28, 2010 | 05:25 PM
JeepaRoo's Avatar
cruise control will usually disable if there is a Tire pressure monitor warning.. or if your tires are inflated at different pressures than each other as different wheel speeds when not turning indicate to the computer that the jeep may be sliding or about to slide (even if the ESP light is not on)
-Christopher
Old May 29, 2010 | 05:57 AM
JKlad's Avatar
Originally Posted by JeepaRoo
...as different wheel speeds when not turning indicate to the computer that the jeep may be sliding or about to slide (even if the ESP light is not on)
-Christopher
Yeah, that sounds about right. One you pick up speed the wheel speed sensors start sending out confusing signals & the system tripps off; may even be just a fauly wheel sensor (check to see if it's thrown a code)
Old May 29, 2010 | 07:00 AM
liquidg's Avatar
that makes sense. I will check the tire pressure first, then check for codes.
Old May 30, 2010 | 03:51 AM
NH-JK's Avatar
Default Weird
What year is your jeep and how many miles? Is there any warrant left?
Old May 30, 2010 | 06:06 AM
bcramlet23's Avatar
find anything yet?
Old May 30, 2010 | 08:04 PM
RA032726's Avatar
Banned Member
Have you checked to see if it is throwing any codes?
