Sponsored by:
Sponsored by: DashLynx
Weird problem with ESC/ETC
Old 07-25-2014, 05:59 AM
sean.peters's Avatar
Default Weird problem with ESC/ETC
Gents - strange problem with my 2012 JK. Went to start it this morning, and the ESC and ETC lights both came on (ETC light was flashing). The Jeep runs really rough now (yesterday all was fine). Hooked up the code reader, and it's not throwing any codes. Any thoughts on why both of these indicators suddenly came on?
It's got like 50k miles, and the tires, suspension, etc, etc, is stock.
Old 07-25-2014, 07:21 AM
14Sport's Avatar
I would start by looking at all 4 wheel sensors. See if a connector came loose or broke. Especially if it has be drooped lately.
Old 07-25-2014, 09:03 AM
Mark Doiron's Avatar
Do you still have the stock battery? I'd have it checked. A weak battery can cause weird performance from the Jeep, including a variety of dash lights.
Old 07-25-2014, 09:57 AM
airborned's Avatar
Mine had the same type of problem. I had to replace one of the wheel speed sensors.
Old 07-25-2014, 10:36 AM
Just to be clear, did you also experience "rough running"? Or maybe I'm reading something into OP's description and he actually meant the ESP was kicking in causing uncommanded braking (which I have seen wheel sensor problems cause), and not a rough running engine.
Old 07-25-2014, 11:27 AM
14Sport's Avatar
I see what you're saying, Mark. He wasn't clear whether the engine is running rough or the Jeep is performing rough. I suspected the wheel sensors because that usually throws 2 or 3 lights up dealing with traction control. I thought the low battery threw 4 or 5 lights up but I could be wrong. Both good things to check though.
Old 07-25-2014, 12:17 PM
They both seem to vary in lights showing. That was why I cued in on the rough running. But it isn't clear what he meant.
Old 07-28-2014, 02:30 PM
The engine's running rough. There's no uncommanded braking that I can detect. It seems to be in the so-called "limp mode". I can't see how the wheel sensors could be the issue... the problem exists even while idling and not moving.
Thanks for the input so far.
Old 07-28-2014, 02:32 PM
Also: if the battery was the issue, wouldn't I see it in the form of it being slow to crank, etc? Nothing like that is in evidence - the Jeep cranks fine and starts right up. It just runs really poorly once it starts.
Old 07-28-2014, 04:17 PM
Yes you should. Hmmm.
Quick Reply: Weird problem with ESC/ETC
