Weird trouble code P1239?
Old Jan 7, 2014 | 05:43 PM
JKshiver's Avatar
Default Weird trouble code P1239?
Hey guys,
my new JK just started throwing this code P1239.. I cant find any information about it online. Do you guys have any idea what this could be??
Old Jan 7, 2014 | 06:03 PM
Biggy's Avatar
http://www.car-ii-codes.com/p1239-jeep.html
Old Jan 7, 2014 | 06:25 PM
ronjenx's Avatar
My 2012 JK service manual says P1239-ENGINE OIL TEMPERATURE TOO LOW
The link above says something completely different. Call the dealer and see what they have to say. You'll end up there anyway for the warranty work.
Old Feb 7, 2014 | 02:59 AM
SubWolf's Avatar
Originally Posted by JKshiver
Hey guys,
I just got the same on my 2014 JK today. My OBDII scan tool shows P1239 "Powertrain", JKshiver did you find an answer for this one? Closest dealership for me is an hour plus drive each way so I cant really swing on in.
Old Feb 8, 2014 | 01:58 PM
SubWolf's Avatar
Called the local Dealership and they are as clueless as I have come to expect. They could not find that code for a 2014 Wrangler. They are supposed to "research" it and call me back but I am not holding my breath. I notice we are both in cold climate areas (Alaska and Canada/BC) so I am guessing what ronjenx found in the '12 FSM is likely correct.
Old Feb 8, 2014 | 02:20 PM
ronjenx's Avatar
Here is the info for the code in question:
For a complete wiring diagram, refer to the Wiring Information .
  • When Monitored: The engine oil temperature has dropped below a calibrated temperature value. Engine start up.
  • Set Condition: The Engine Oil temperature rises slower than a calibrated modeled temperature. When the actual oil temperature falls below the low boundary of the calibrated modeled temperature for three minutes the fault is set. Two trip fault. Three good trips to turn off the MIL.
Possible Causes
Engine oil
  • OEM recommended oil viscosity is being used.
  • Customer is following the oil change schedule.
  • Check the engine oil for contamination. (i.e., fuel and/or engine coolant).
  • Internal engine condition that may effect oil pressure.
Engine oil temp signal circuit high resistance
Engine oil temp sensor ground circuit high resistance
Engine Oil Temperature Sensor
Powertrain Control Module
Old Feb 10, 2014 | 07:32 PM
SubWolf's Avatar
Thanks Ronjenx. Code cleared without issue, I am not going to worry about it unless it returns.
Old Feb 26, 2022 | 09:43 AM
MusicMaverick's Avatar
Resurrect This thread… I just had this code pop up for me last night. I also have a ‘14 JKU… looks like there was a service bulletin on this issue. Anyone else run into this code in recent years? Seems like it might just be a matter of having a dealership reflash the PCM or ECU, but curious if others have had experience.
https://chrysler.oemdtc.com/936/flas...-jeep-wrangler
