Weird won't start issue
So at an increasing rate (was about once a week, now about once a day) I go to start my jeep and it will start, not quite get enough RPMs and then die. When I go again it just turns over but won't quite get cranking. After giving it some time I can usually start it up. I had the battery checked and I am at 95%. Now my red battery light comes on almost every time I get in the jeep thought. Please!!! any suggestions would be awesome.
I should also add I have a rough at stoplight and sometimes it seems almost as though my jeep is going to stall out at red lights and such.
Thanks! I just took it to the dealer but I get such a hassle. They almost always send me home at least once without fixing the problem. I will keep the Cat in mind. Wound that cause the red battery issue as well?
Doesn't sound like a battery issue, if your battery was running flat it wouldn't turn the jeep over. I think I read some threads about the factory alarm causing something like that. Turns over, starts to fire up and shuts right back down, then just turns over after that. Try a quick search about alarm trouble.
No alarm.
